Trouble Connecting SQ7 FOH to SQ6 broadcast
We have an SQ7 installed for FOH. Some inputs are local into the board and some are cconnected to an AB168. Then we installed an SQ6 for broadcast. We want the 2 boards to see all the inputs going to the sq7. The problem that the sq6 see all the sq7 inputs except for the inputs coming from the ab168. Is he trying to do everything with one slink?? What do we need to add or do to get this working?
I think you will need to purchase an S-Link card for one of the consoles. The SQ-6 and SQ-7 will be link together with a dedicated network cable (minimum STP CAT-5E) on the GX protocol and the open S-Link port will be a dedicated network cable (minimum STP CAT-5E) to connect to the AB168 on the D-Snake protocol.
This way the consoles will see each other and the stage box and will be running different protocols on each dedicated line.
If your stagebox is hitting the SQ7 via one “card” and the SQ7 links to your SQ6 via another “card”, then you have what you need. It’s just a matter of patching the correct tie lines to the 2nd card.
