Also, I don’t imagine that it’s possible but it would be nice to be able to bank down to the next 16 faders in ProTools with the QU like the HUI and other controllers do. I realize that I’m asking much of a small format digital mixer that is used by most in live situations.
Not the answer I wanted…I guess I have to revive my old HUI, consider AVID Artist Mix or spend big $$ on the Raven MTI to be able to control my PT session. I was hoping that HUI mode might include more function than fader, solo and mute.
Where is there documentation that illustrates the custom assignment of bank up/down to soft keys. I found the info on pg. 42 of the manual that shows the 7 different functions (8 including unassigned) for the soft keys. How am I to program bank up/down to go from PT tracks 1-24 to 25-48.
Having the same problem: I’ve my Qu-24 running fine as a controller for ProTools (11.2.1). Everything works great except I can’t pan a channel left and right. I assumed I had something setup wrong in the I/Os. I’m not quite sure I’m reading the answer above correctly… did Nicola A&H say this isn’t possible? (!) Mixing music with no ability to pan things L/R is not ideal, obviously. Any suggestions on a workaround?
The workaround is simply to set your pan within the DAW using a mouse… am I missing something? Unless you Intend to keep changing the pan during the mix… Even then, automate it…
