If i call the routing screen for an input there are two channels which named “main”. Through testing I see, that the first is the true main and the second is the mono main out. In my opinion this naming is confusing. Can you replace the second “main” with “mono”? I dont know whether the main outs in surround config are named correctly or not. Can someone check this?
Hello CeDoMain,
I don’t know if I understood you right:
In general there are some options how you can configure the “main-bus” for your show.
There is 2 Mono (then they will be named “Main 1” and “Main 2” which is L/R or you can combine them. Also you can have a LCR Master, then you’ll have L/R as “Main” and C as “Main”, but L/R will be labeled with ST.
But you always can change the names.
And there is no “true” main it simply depends how you configured your show.
Cheers
Hi Pete,
I agree to you. I can change the name of the Main-Outs and my dLive change the name on displays an labels. But the ROUTING SCREEN does not display theese name. It displays only “Main” for LR-Out and “Main” for C- or Mono-Out. This is confusing.
Hope you understood now what my problem is.
