I have indoor and outdoor performance stages that are both in the same venue (only one stage is has live band at any time). When no bands are on I play one iPod on both stages. When a band is onstage outside (Qu-SB), I send the LR signal to the inside stage (Qu-32) via Matrix to and input channel. Same set up for band onstage inside, I send LR to the outside via Matrix to an input channel. The ipod lives with the inside Qu-32 and plays continuously, i just mute it when a band is live.
Is there a better way to do this? I only know enough to be dangerous and find myself being soundman, bouncer, bar back, trash guy etc. so simplicity makes my life a bit easier when things really get busy…
The muting and unmuting process is kind of complicated and I recently blew or fried something on my inside Main PA. I think I sent the Ipod outside and then the outside sent it back inside and we went for some kind of loopy ride real fast until the system broke…
Steffen, the problem with that is possible noise being picked up in a long unbalanced cable.
What long, unbalanced cable would that be? You simply split the signal into two channels of the Qu32 instead of feeding it into a single channel as is apparently being done now. Use ST1 and ST2 or whatever. Less fiddlish to mute each send as required.
Stereo will require 2 balanced cables and di boxes. Maybe you could set up a mute group that will block the chance of a loop and assign it to a softkey.
Not necessarily. There are several options depending on equipment available, length of run, etc. Cables and DI’s are just one option. Hard-wired connection of two systems should incorporate transformer isolation in any case. If OP has a spare IEM rig, the send could be wireless and obviate need for the transformer.
A few years ago I was asked to help a large choir singing while walking between two churches, and needing to take their recorded accompanying music with them.
One source was not really enough, as they were getting on for 100m from one end to the other for much of the walk, so battery powered PAs in two trollies was wanted. After much experimenting, I ruled out wireless solutions as being unreliable, but found that 2 iPods, with identical playlists, stayed in sync perfectly for the 45 minutes required. Tested, by doing the walk with the MD, with one earpiece from each iPod in each ear. The iPods were the same sort, which may be important.
Unfortunately, there was a massive thunderstorm on the evening it was supposed to take place, so we never actually did it! However, I’d suggest that 2 iPods would be a simple solution to the problem here.
