Greetings –
I need to connect two of my iDR-32 outputs into a single 1/4" TRS for driving a stereo mix into personal monitor mixer.
Can I wire it up like this?
Output 4 - Pin 2 to 1/4" tip
Output 5 - Pin 2 to 1/4" ring
Output 5 - Pin 1 to 1/4" sleeve (or should I take pin 3?)
This isn’t so much a question about the proper way to wire up the adapter, as it is a question about potentially damaging my MixRack.
Thank you!
Tim ==
Just make sure you tie pin’s 1 & 3 together on the xlr connector. You will not damage the mixrack.
John
System Integrator
Entertainment Arts Inc.
Why not get a couple of simple 1:0 to 1:0 transformers so the output driver of the mix rack see’s a nice simple load, then you could use the outputs of the transformers to feed the TRS input of your monitor device. Keeps it isolated also which is a bonus less chance of hums and buzzes also.
You should be able to buy off-the-rack cables to do exactly this…
T112|iDR48+ACEcard|Laptop|iDR16|iPad|iPS10
quote:
Something like this, eh? https://www.sescom.com/product.asp?item=SES-XLR-ISO ~USD$20@ plus shipping.
I was thinking of something like this timtrace
But your way work work fine.
