With the last update over a year ago the mixer feels like it may be abandoned.
After thoroughly evaluating the mixer for one week, I’ve located three moderate to critical issues are currently unresolved:
CQ-Mixpad app EULA agreement buttons are not visible on some devices/android versions, and so it cannot be accepted and the app cannot be used without changing display resolution as a workaround.
The only way to rename the bluetooth and usb inputs are from the CQ-Mixpad app, using a “hack” where you select one of them on the processing page, then tab back to the config/inputs page where you can rename it. There is no other way to rename them and this cannot be done on the device.
If you change the name of one of the aux outputs, then tab to the usb/sd assignment page to set your custom returns to PC, the name of the outputs in the drop-down list will not be updated, it will be the old name. You must stereo link and unlink the output pair to update the name.
Hopefully at a minimum A&H pushes an update to address these major issues ASAP, and it would be nice to see them also add any other widely requested features that are possible within the constraints of the hardware.
