I know A&H has a convoluted list of Thumb Drives - what I want is a list of specs instead of drives - that way we don’t have to search the list which to say the least is nonsense to me - but if you have Drive Specs you wouldn’t have to search for a drive - you could just put the specs in a search engine and then buy the one you want - or perhaps this is already done and I have seen it? Also what is the reason for various drives working a QU/SQ/DLive/Avantis but not each other? -
Unfortunately its not that simple. I have thumb drives that are the same model two years apart and one works and one doesnt. Specs are identical.
I gave up trying to crack this nut a few years ago because I found the Samsung T7 has been rock solid. Bought a dozen and didnt look back. We reccomend that to all of our customers as well and its held true over time and the T9 has followed as well.
Knoble request, but Im just saying at some point youll spend so much time testing that its not worth it.
I’ve landed on the Samsung as well - personally I think they should just limit the USB and Drives to 4 approved versions.
Sandisk 1T or 2T SSD operates perfectly and fast on the SQx consoles
The issue with usb thumb drives is that the market is flooded with cheap stuff that looks legit and might even achieve the advertised specs during the first writes. But as soon as the available flash memory was written at least once, their performance will plummet.
Also, just because a thumb drive has a usb3 interface doesn’t mean that it’s ‘fast’. There are at least two components involved: the controller chip might not even reach USB3 speeds under optimal conditions and the attached flash storage might be even slower. Then there are issues of what the controller does with the flash storage chip it’s controlling…
When you look for USB SSDs instead of “regular” thumb drives, your chances of sustained performance over the years of usable life will be higher. The mentioned samsung t7 or t9 drives fall into the latter category, as do the mentioned sandisk ones…
