USB Audio 31/32 to Ableton
I am running the qu24 along with Ableton as part of a live session studio mixing external and plugin gear and need a way to return all IN channels of the QU24 into Ableton in order to apply controlable (via MIDI controllers) FXs to the main mix then back to the QU24.
I have setup all ins & outs in ableton preferences but can only receive audio up to the first 24 channels. Is that normal where as I receive all 32 audio channels within an external multitrack recorder like BOOM RECORDER?!
thx for the help
I have a QU-32 and am able to route 32 in/out over USB to Ableton Live 9 Suite. Have you made sure all of your sources in the QU are set to use USB B?
That’s a good point Mal! On the qu24 I only have access to CH1 to CH24 + ST1, ST2 & ST3 to set up USB B (see attached pict). ST1, ST2 & ST3 are set up for USB streaming but aren’t coming in either in ableton.
The strange thing is that it is coming in fine in Logic or Boom recorder…
How is your Input Config setup in Ableton?
All inputs (mono/stereo) are activated in Ableton preferences and input 31/32 selected on an audio channel.
I’ll send a screen when I get back home this evening…
not sure what happened but it works now… :slight_smile:
Thx for your help Mal!
