Hi all
I tried searching for this problem being listed previously but couldn’t find any topics. Please point me in the right direction if I am wrong.
I have a 48kHz, 24bit multitrack recording I made years ago that I am using as a means for testing out the desk. Similar to a virtual soundcheck, I guess.
After much fooling around in Logic 8 to set up mono sends from the 15 audio tracks in Logic to 15 QU24 channels via USB-B, I am able to get each instrument coming in on its own Qu24 channel.
I hit play in Logic and the song starts and the instruments all play back as expected. Cool!
But after a minute, or even sooner sometimes, the playback starts breaking up. The best way to describe it is that a decimator or bitcrusher is being placed over the main output and slowly being cranked up until the audio just glitches out completely then stops playing altogether.
This is what I have tried so far:
Setting the Qu24 inputs to ‘Local’ then back to ‘USB-B’ doesn’t help.
Turning the Qu24 off and restarting Logic works, naturally, but it doesn’t solve the problem.
Checking digital sync - In my Audio/MIDI setup the Qu24 is the master controller by default when Qu24 is selected as the playback device. This cannot be changed, so I don’t believe that this could be the cause if the system has set this up for me.
MTC playback synchronisation - set to continuous in Logic. I have tried other MTC options but it doesn’t fix the problem.
Resetting the audio playback device in Logic to ‘Internal’ then back to Qu24 and letting it resync itself helps but then it happens again a little while after I start playback.
Pulling the USB cable out and plugging it back in to let Logic relocate the device and resync to it has the same affect as playing around with the audio playback device.
Nothing I do seems to permanently solve the problem and eventually the audio starts breaking up again.
Has anyone else experienced this and can they help me to fix the problem?
It is extremely frustrating!
I tried making a recording of it into a Qu-Drive to post a sample but the resultant stereo file was blank. Don’t know what went wrong there but I’m over trying to get the desk to work properly tonight.
It has the latest firmware V1.73 which came pre-installed as I only bought the unit home last week after it had to be ordered in from overseas.
Any suggestions greatly appreciated.
Dags
