Hello everybody, whats good?
So I`m working with a QU32 on a studio and Im having a problem setting the USB B Channels. Id like to set the musics that I play on the computer (youtube, Itunes for exemple) to return to the channels 31/32 which we don’t use here, but I can only set it to channels 1 and 2, how to proceed?
Notes:
I already set the Gobal USB Source to USB B Streaming
Hi Nebonts, which DAW application are you using?
You need to set the outputs from the software to the corresponding channel of the mixer.
There is a video tutorial here which might help: https://www.youtube.com/watch?v=v8opaijoJbY
I`m using Pro Tools, but there nothing wrong with it. In the daw I can select which channel to use. The problem is with Itnues, youtube, spotify… Programs whch I can’t choose I/O settings. Seems like the 1 and 2 are the default, and Id like to change that.
Hi, I’m having the same problem but with a PC. We’re trying to use a Standard Windows 8.1 Laptop for basic stereo recording and playback. I’ve installed the A&H driver but am getting stuck.
For Playback I set the Default Windows Audio Device as Qu32 and play something using media player etc. It lights up on the Windows control panel but nothing seems to appear at the desk. Following the instructions I set it up by going to the routing on ST1 and changing it to USB and Selected USB B Streaming However I get an X in the St1 box. Instead I tried to use channels 1-2 and was able at least to change them to USB B. However still no audio.
For Recording I used the Setup->USB Audio screen to Change Channels 1-2 to LR-L and LR-R but nothing arrives in control panel to the QU32 Recording device.
Thanks, I’ve managed to get the signal into the laptop (albeit it’s very quiet) and wonder whether there’s any way of controlling the level sent from the desk?
In terms of using ST3 I used the function key on the ST3 channel and changed the routing from local to USB. However it comes up with an X. Although the Windows driver appears to show a good strong signal leaving the laptop there’s just nothing arriving at all at the desk. Perhaps I’m missing another setting somewhere?
As Nicola said, if you’re using a Qu16 or 24 the Windows audio should show up on St3. If using a Qu32 then the Windows audio will show up on Ch31 and Ch32. It’s ch31-32 whos sources you need to change to USB-B, not St3’s.
Thanks all, pleased to say 31/32 all works week (although a shame to have to give up 2 physical input channels). Still got a very clean but very low level UBS signal coming out of the desk though.
The level is dBFS - if the desk is running at a nominal 0dB (as you would have done in an analogue world) then the signal will be at -18dBFS.
This is good, you have 18dB of headroom.
The signal is 24 bits deep, so you can amplify it later trivially - there is plenty of bit depth available.
The bit depth (8 bits more than a CD, which is as much as the human ear can hear) can be used in two main ways:
a super low noise floor for recording in a studio where you can have multiple takes and expect to make thousands of post production modifications.
a decent headroom for live situations, where you really want to avoid digital clipping - there is enough depth to have headroom enough for the most exuberant drummer and still have a very low noise floor.
You balance your signal levels between these extremes as appropriate for your situation.
If you want a ‘hot’ signal coming back to the PC then run the desk extremely hot - risk clipping, but have negligible dithering noise.
Else just boost the level in post production.
[XAP]Bob, I think you might be confusing the term “bit depth” with “sample rate” when you talk about how it relates to human hearing. True, 24-bit depth is 8 bits more data than a commercial CD and allows for more processing modifications in studio without degrading the audio quality of the file, but it is sample rate that is directly related to the spectrum of human hearing. A recording with a 44.1kHz sample rate will produce half that number (22kHz) as the highest frequency in that particular file, just as a recording using a Qu console will produce a file with a 48kHz sample rate and make the highest frequency produced 24kHz.
Sample rate for frequency, but depth for dynamic range.
Both are “limited” in human hearing - 44kHz is overkill, but give a bit of room for a decent analogue filter to exclude Nyquist violating frequencies, so that’s good. 48kHz allows better syncing with video - that’s the obvious advantage, an integer of samples per video frame.
The dynamic range of the human ear is about 15 bits - 16 is mild overkill, but very convenient for computing…
Taking 8 extra bits gives a huge dynamic range, which we can exploit for an insanely low noise floor (assuming clean signals of course) or a extremely high transient capacity.
I have a problem…
we are using the apple camera adapter, and USB B streaming l… we use it for live recordig. But i only hear one output going in… and I have no idea why
(I only hear one mic… the band and other singers are not going inside the ipad)
