When I use the asio driver(w8.1 64x) for streaming audio in my QU16 mixer, the first 30 seconds works it, but than a noise/destorsion come over the signal. Does anbody recognise this? OR can anyboy tell me how i can solve this problem?
Similar problem here (same OS)… Sometimes it just freaks out during playback all screechy… Can usually be stopped by stopping audio and then restarting… But it’s annoying…
See if my thread sounds similar…
https://community.allen-heath.com/forums/topic/qu32-screeching-during-playback
Could it be a too
Small Buffer size? I had this problems with another setup a few years ago! I had to set a higher latency from the audio driver! Can’t tell you if this is possible with the asio driver!
I don’t know the real problem. A hard reset solved the problem. A lower buffersize has the same effects.
