USB file reader
A few words just to ask you if it would be possible for you on the occasion of a new release to make some modifications to the stereo file reader part (from a USB key) of CQ firmware.
Before using CQ we used a separate backtrack player (We prepare different backtracks with the instruments needed and generate stereo wave files in order to play for example without our drummer …) now we use only the CQ with its ability to play wave files. Could this part of the CQ firmware (Stereo Playback) integrate ?
  • Could the zone “Select track” witch calls the window “Select track” always display left aligned names of files like its linked window ?
  • Could the Previous and Next functions that are assignable to the Soft keys only do Previous and Next file not followed by Play action even when in play mode (Stop+Previous or Stop+Play)
  • For those who do not use multitrack recording, making the choice in the config section could the SD also work like the USB stick (reading stereo files) ?
  • Would it be possible to have différents projects on the same disk (AHCQ > USBPLAY > List1
    List2
    List3) or
    (AHCQ > USBPLAY1
    USBPLAY2
    USBPLAY3)
  • Could the “Select track” highlight the file in progress without having to close and reopen it ?
Thank you ?
