USB Input 13-14, 1-2 instead
Hello, I have an suggestion.
I am using the the CQ12T via Core Audio on a Mac.
If I want to playback a Signal (Music, Teams, …) the Mac sends it on channel 1-2, that means I have to use
the first two channels for the USB stream and am not able to use them for microphones.
Is it possible to route the USB from 1-2 to the USB channel 13-14? Or will it be possible in future?
greetings Wutschgo
you can configure the CQ-12T as a multistream device. You can do this in the config-tab inside the CQ MixPad. With this, there is a dedicated USB-channel for audio coming from the pc or mac. So you don’t loose any inputs. I have the CQ-20B under Windows 11, but it should be the same with the CQ-12T and a mac. Try this.
