Hello, I have the problem, that several programs (MainStage, Native Instruments Kontakt, usw.) only send signals to the CQ via USB1&2, it is not possible to rout them to the USB Input 13&14.
The Problem is, that I need all my microfon inputs.
Is it possible to implement the possibility in the next firmware to change the USB Input from 13&14 to 1&2.
And a second suggestion, please implement the possibility to send Busses to USB output 1&2. I sometimes have to send multichannel Signals to Microsoft Teams, at the moment I connect Bus 1&2 via cable to Input 1&2 to do that, but it would be much easier to route the Bus directly to USB 1&2.
Thank You!
Wutschgo
The fact that you’re using MainStage suggests that you’re using a Mac, so no driver is required.
In the CQ there are two modes for the USB interface mainly for this reason (simple 2x2 interface for things like teams or streaming and multitrack for pro audio) - but it sounds like you might be wanting to use both at the same time with lots of inputs and a stereo output that goes to a stereo channel.
What should work for this on a Mac is to set the CQ to multitrack, then for your system sound output go to Audio MIDI Setup (Audio Devices Window), select the CQ and on the outputs tab click ‘Configure Speakers’.
Here you can select any of the USB channels for the system output (e.g. 13&14 if you’re on a CQ-12T).
Now in your sound settings, select the CQ as your output device and then just point your apps to use the system audio.
Normaly the routing to 13/14 is workin great, with programs like teams, music, safari, eg., but with MainStage or Native Instrument Kontakt it does not work,
because these programs automatically use the USB Output 1/2 and I have not found a possibility to change that to 13/14.
