The Library popup for Input Channel/Gate/PEQ/Compressor should allow the user to save a library to USB. You can overwrite or delete a USB library entry once it exists on USB, but you can’t create it on the USB from this popup - you have to go to Utility and copy it to USB. This seems inconsistent and cumbersome.
It would also be helpful on the same popup to be able to filter the list to show only USB entries, as currently you can only see them all mixed in with the user library entries.
Andrew
