USB Multitrack recording to DAW not recording all tracks
Hi all, I just recently had a session where I had a Macbook connected via USB to an SQ5. I had patched all the channels (that I was using) to USB in the IPDirect Outs in IO. The problem is two tracks didn’t record anything. I didn’t have time to check every track in the DAW (Reaper) when we setup, I saw bouncing meters and figured since all tracks were patched the same I was good to go. Has anyone experienced this type of thing before? Is there some other setting I should be checking to make sure a track is fully routed to USB out for multitrack dumping a recording?
The only time I’ve had this happen it was a patch error in Reaper, due to operator inattention. My fix to keep it from happening again is to zoom out until I can see all of the Reaper track meters at the same time.
