usb problem
hello everyone i am using the t112 and im having a problem upgrading
to the new firmware.i keep getting a message check usb key firmware
not found. iv tried the usual stuff different keys but no luck.
can anyone advise?
deltamax
alan nolan
Try checking usb key is USB 2 and that the firmware isn’t in a folder on the key
www.maltingsaudio.co.uk
many thanks
alan nolan
Hey alan do get the probelm fixed?? I have the same Problem with my T80 Surface! After an service i get my surface back with the FirmwareV1.63 and on my mix rack is the Firmeware V1.53 and now i´m not able to do any Fimeware Update couse the Mix Rack is a China Version where i can´t updatet by the Editor, and my Surface diden´t show me any USB Key´s
Hi Deltamax
Do you still have a problem upgrading your firmware?
Seb: Please contact Allen & Heath Technical Support they will be able to help you resolve your issue
[url]https://allen-heath.helpserve.com/
[/url]
Regards
Sam A&H
Hy all,
I fixed my Problem! The ILive do not read all USB Sticks. My Intensio and Sony Sticks are not compatible to the ILive. The German A&H Support recommend USB Stick from Sandisk and it works fine!
Hi Seb
Glad you fixed your problem.
Do you know if the USB sticks that do not work with iLive have partitions or hidden partitions on the key?
Regards
Sam A&H
Hey Sam,
The USB Stick have no partitions or hidden partition! My German A&H Support told me that they know about the problems with the Intensio Sticks, and they recommend to use USB Sticks from SanDisk!
Best Regards
Sebastian
