Out of interest, do you therefore anticipate needing to use GB of Audio files ? I’d be interested to get feedback on how much audio people need to use.
I thought to keep it quicker and simpler to navigate, users might put a smaller collection of MP3’s for use with the current show on a USB Key, instead of having to navigate up and down complex tree hierarchies of Audio every time they wanted to play something.
To answer the power question I’m pretty sure its 500mA per connector, so it depends on the external hard disk. Some externals use more power than this and typically come with a Y shape lead, so they can use power from more than 1 connector. But you should be fine with a USB 2.0 external which draws 500mA.
Size limit will be defined by filesystem type. Note the GLD only works with FAT, as almost all USB Keys come by default with FAT filesystems.
Fat has several sub variants, and the maximum size depends on which type you’re using:
For record, we recommend no more than 3 hours per track.
Personally I have a 8 GB pendrive always with me and it’s enough, both for playing and recording.
Talking about playing, I’m with you Andy, when you say “keep quick and simple”, but without folder support, you have all the mp3s mixed up in the alphabetic order, regardless of subfolders.It’s not that simple…
My best view of this facility is try to implement a “virtual cd player”, where I choose an album (a subfolder or a playlist) and then playing it from beginning to end, also with the possibility to repeat or shuffle the whole album. Nowadays I already can do it with a ripped cd on a single flac or wav file, but I loose the single track control.
Andy
A&H
Having support for multiple files would be nice. At my show last night I needed to do walking music, show music and exit music. I had to rename all the files to get them in the correct order. Had I been able to have folders I would have already been there and it would have saved a lot of time.
