The recording work fine. Each time a new recording is initiated, the name increments properly. The memory stick works fine on a laptop. The only thing is, the recordings don’t appear in the play list so they can’t be played on the machine. Any tips would be appreciated.
I think it’s the same on SQ and dLive…
Problem is that the recordings are saved to the record-folder, but the player just looks at the play-folder. Unfortunatly you will need to push the recorded file to the other folder on your pc/mac. Maybe a good suggestion for the next firmware update(s) also for the other consoles…
I don’t understand here…
I have access to my record in the USB stick in the CQ12T, just select the recoded folder.
Don’t you have the 2 “playback” and “recording” folder switching option available ?
Thanks Willmodelisme. The window that shows recordings does not automatically register a new recording until you press it. Based on your screenshot, I messed with it until I found how to do it.
