USB stick for stereo recordings
I understand the need a fast read (>100 mbps) USB stick for Qu Drive multi-track recordings, but for stereo (or mono) podcast recordings what is the minimum recommended USB
Hi Gilly, there’s a thread on user approved USB devices for Qu-Drive here: https://community.allen-heath.com/forums/topic/qu-drive-compatible-usb-device-database
We recommend testing the device if possible as manufacturer specs change every so often which may affect compatibility with Qu-Drive.
It may be worth using a retailer with a good returns policy, so that you are able to verify the device works 100% and return it if not.
Hope that helps.
Harry.
