Hello,
We recently have installed a QU16 in our church for recording services.
We are trying to record into Audacity but the input level is very low.
Also, we will be live streaming with Wirecast, but again the audio input is low.
I’m new to this board so any helpful hints would be appreciated.
What channels are you recording, and what is the meter reading of these channels on the desk?
A meter reading around 0dB should correspond to ~ -18dBFS in your computer. This is normal and allows for headroom in the converters to avoid digital distortion. You can then compress / maximise and normalise in your DAW. For live streaming, check if Wirecast has an input trim as suggested above. Using compression on your mix output on Qu would also help with the dynamic range.
You might be having gain staging problems. You can turn down the master output on the mixer and up the peamp input gains. As I said elsehwere, observe the meters section where you can see all the channels, and see that you have a healthy amount of gain there. It is pretty simple and basic gain range probably.
When running both live sound and sending program for recording/streaming, you need to be able to set your channel/recording levels at the optimum level and have control over your live sound output such that you can adjust it as needed for your sound system. I do as follows:
Set up your recording levels first.
Use the “Alt Out” connections to feed signal to your live sound system. You must go to your output assignments and choose the source for the Alt Out jacks (balanced TRS). I run my live sound in mono, so I choose “L + R” as my option. I can then use either one or both Alt Out jacks to feed live sound.
You can now run your board as needed for optimum record/stream level and control the level of the live sound feed with the Alt Out knob. This will in most cases mean that you run your Master fader for the proper record level and REDUCE the signal to the live system as needed via the Alt Out pot.
This is how I handle doing live sound, Shoutcast streaming and recording all at the same time.
Clear?
