Use soft keys to change effects preset
I wish you could assign soft keys to change effects preset.
Would be nice to switch from a large hall to small room with the push of one button!
Ron
i think this should work by using 2scenes with recall-filters! Maybe you just can set the global filter to “Block everything except FX Parameters” or another solution may be a scene where you safe everything except the FX Return! Probably the Send-Level will change with the scene!
That would work.
Although I can see myself changing the whole board right in the middle of a song, pops in sys from phantom power going on or off!
Will have to experiment.
I still think the soft keys should do this.
Well i think if you just want to change the FX that should work without any pops! I use scene a lot during shows and never experienced problems… well yes you have to check that first if it does work for your changes!
