Hello all
I am using a Cymatic LP 16 multitrack player to send 3 wave-file tracks to my SQ-6. A left/right stereo track and a click-track for the drummer.
Does anybody know if it is possible to do this straight from the multitrack playback possibilities inside the SQ-6?
If so, do I need to arrange/rename files and or folders in such a way that this would be possible using wave files not created and edited with the SQ itself?
Any help or suggestions would be very welcome!
Thanks all
I am able to answer my own question.
The wave files I have I converted from 44.1kHz 16bit to 48kHz 24 bit PCM WAV files as specified.
Then I assigned the SQ-Drive to 48kHz, assigned input channels 1, 2, 3 on USB to resp. Seq Left, Seq, Right and Clicktrack.
My patches on the console I then assigned to the same USB channels
Click track only goes to the AUX channels (monitors), I turned off the output to Master
And one stereo seq track on the board did the trick for me.
It took a bit figuring out which WAV format the files needed, even though I knew what it needed to be (according to the manual)
Perfect!!!
just a small remark…
the word sequenzer is misleading in this context
it’s just a recorder/player…
and your reference guide is outdated…
https://www.allen-heath.com/media/SQ_ReferenceGuide_V1_5_0.pdf
file format description on page 94
