Sorry if the following has already been described somewhere.
My concern is the displaying of the Processing Screen while using “CH to All Mix”.
For example, if I have 24 inputs (SQ-6) in my layer and select inputs 1-8 for “CH to All Mix”, I will see mixes 1-8 on the screen - ok.
If I select inputs 9-16, why I see now the mixes 9-12 and the 4 FX?
If I select inputs 17-24, I don’t see anything!?!
The thing is that the processing screen follows the temporary fader bank (12 mixes + FX) that appears during the “CH to All Mix”.
What makes no sense at all is that the position of the selected input determines the section of this temporary fader bank on the screen.
It would be much better at this point to see which input i currently using.
And it would even be helpful if it temporarily switched to Routing - Sends instead so that i could still see important parameters of the mixes such as pre/post, assign, pan and level during the “CH to All Mix” process.
