User Defined Qu-Pad App Settings Screen
Here’s my list of Qu-Pad changes:
Create a “User Defined App Settings” Screen – please create an app settings screen and place for users to configure how the app works.
User App Setting Suggestions:
a) Device Connection Time-out Setting – allows the user to specify how long in number of minutes the app will stay actively connected to the mixer before it logs out due to inactivity. (We use the Qu-Pad app as a “plan b” interface. We want to log into the app and mixer prior to the service, then leave it sitting nearby in case an issue comes up. However, the few times we needed it, the app had already logged out, causing significant delays in responding to the issue.)
b) Freeze App Update – app will not update when this box is checked. Allows for manual coordination of mixer/app firmware versions.
c) IDEAL: Store/Recall App Version – app retains more than 1 version on the iPad and the user can specify which version to load. This allows the user to select which app version to run so that 1 iPad can be used in more than 1 setting where the devices may be on different firmware versions.
d) Screen Timeout Block – When checked, app will block the iPad from blanking the screen due to inactivity. Keeps the iPad screen actively displaying the app for long periods of time.
