Yes you can use MIDI automation for the console however it really only works for mute/pan control.
If you do fader automation the iLive glitches quite badly and does not give smooth fader movements. In some cases it wont even recognise fader movements.
And Scene recalls via MIDI work also - certainly not sample accurate though! If you have many automated fader movements happening at once then thining the MIDI data stream might help.
I would have thought the compression/EQ/Effects etc already in cubase (or third party) would provide good results without the hassle of trying to integrate i/o and automation with the iLive.
quote:I would have thought the compression/EQ/Effects etc already in cubase (or third party) would provide good results without the hassle of trying to integrate i/o and automation with the iLive.
Actually they do. I’d still prefer to use real faders though, If only I could get auomation to work.[ ]
