Hi, I have been using our church’s CU-32 for a couple of months. A video that was very helpful no longer seems to be available on YouTube, so maybe someone can help. We set up Mix 9/10 as our “Streaming Mix,” sending that mix to our LiveStream for TV. We set up all the channels that we use for post fade - so, any adjustments made in LR is automatically adjusted in Mix 9/10 - but not vice versa. For some reason - I am not getting the effects in the Mix 9/10, though it is showing up nicely in LR. Any thoughts? What am I missing?
did you insert fx into mix 9/10?
my block diagram does not show that any changes in LR can affect the mix.
dont you have to select mix 9/10 and make the changes yourself?
-Select Mix 9/10
-Select the top layer on the mixer.
-Bring up the faders on the needed FX return channels.
Same process as adding any other channel to mix 9/10
