I a qu-sb mixer.
I’m trying to record the gigs i’m mixing using the qu-drive on-board software.
While using SunDisk’s disk on key I was able to record multi channel gigs up to 50 minutes with an 8 Gigabyte disk on key, although most of my gigs are longer than that.
I was also trying to format 16 and 128 Gigabyte disk on keys using the mixers on board format software but the mixer seems to freeze.
I formated my 128 Giga disk on key to FAT32 file system using my computer and was able to play audio using the qu-sb but had no luck recording, hitting the recored button freezes the system and requires a restart.
Is there any known, checked disks manufacturers that I can use their products with ease?
Is there any other solution you may suggest?
Thank you,
Yarden Karny
