I will be demoing a QU-32 in a local church so they can see if they want to purchase it. To save having to put the band on stage I was thinking of using the internal Qu-Drive functionality to load up some multitracks so that they could have a play with the functions.
To this end I have already found out that the Qu expects 18 24bit/48KHz files of the same size, following the particular folder structure of its own recorder. I also found out that I need to avoid broadcast chunks. However I have seen that some people still have issues.
If I download multitrack files from one of the free sites on the web, I presume the easiest way to do it is to load them all into Reaper and then render them out. Has anyone got any experience doing this, who could advise on any potential pitfalls? I will be getting the desk on the morning with the demo on the afternoon, so would rather avoid dealing with multiple export/re-export troubleshooting loops if I can avoid it.
Most foolproof way would be to play out through Reaper to the desk, and record as you do so. You’ll not need more than 20-30 minutes of audio will you?
I mean, thanks for being patronising but a) not my sale, I’m consulting and this is the desk we’ve decided is the most likely candidate: I get paid the same regardless. B) I already said the desk will be arriving on the same day, so no I won’t, hence the need to sort out potential issues in advance. Thanks for your concern though.
Fwiw setting the streaming up from Reaper seems like a much less problematic and time consuming way of demoing the system for them so I shall just do that. Thanks for putting me on the right track.
Is the PC or Mac you will be using been used or set up for that streaming to QU desk before?
I take it you know how to quickly set the routing up to do this?
I’ll be using a mac. I’ve looked through the QU manual and the desk routing seems simple enough, and I know how to set up reaper. Thanks for your kind wishes.
