Hello everyone. I am trying to use the Qu-Pac as an audio interface and I’m having trouble getting the routing done correctly in order to use the headphone jack on the front of the pac as my monitor source. Does anyone have any insight on this?
I am using Pro Tools 12 with Windows 10. I believe all the drivers and firmware are up to date.
When selecting PAFL on any channel or mix will bring that source to the
headphone jack. With no PAFL selected you will have the main LR at the headphone
jack.
You can select in the set up menu to either have the PAFL additive to select multiple
sources and listen to them all that same or in single solo mode.
You can also select the pick off to be pre fade or post fade.
