Using Qu pac with SQ7
Hello! Does anyone know if the Qu Pac 24 is compatible to be used as an expander with the SQ series?
there is no Qu Pac 24…
you can use a QU with a SQ together
but it’s not exactly the same as an expander
I’ve done this. It took me a while to get my head around the correct routing, but it’s all saved in the library now for next time, if there is one.
Remember to set the QuPac as the master clock, and that you’ll need to control Gain & Phantom from the QuPac (but a tablet makes this pretty easy).
@MarkPAman I have a few questions if you’re willing to answer:
  1. Can you give me an idea of what the routing should look like?
  2. How do I set the master clock?
  3. Does the gain control/phantom power have to be controlled by the QuPac for all of the channels (including SQ) or just for the channels in use on the QuPac?
Kieth explains 1) & 2) well here:
  1. Each desk controls its own preamps.
If you want, I can look at my saved patching and screenshot it, but probably not until the weekend.
Excellent! Thank you! I didn’t know this video was out there!
