Hi, with 1x R72 and 1x idr rack (32/16) trying to patch same inputs in different channels for use as both foh and mon , I can use the same input and “split” it to lets say input 1 on foh and input 31 for monitors, I can also set pre amp gain on surface for ip1 and trim on surface for ip31 but…that means the paths are not quite separate…i.e. if I select a different pre amp gain at foh, then the value will change in the monitors!!!“”" so maybe this is not the way to do this??? any other ideas on this???
Set the initial gain at sound check with one DSP channel set to “preamp on surface” and then change both split channels to “Trim on Surface” Now either FOH or monitor can adjust gain (Trims) without effect to the other. If after some mix time you discover that both FOH and Monitor trims are set the same-( for example -6db) then you could change one channel back to preamp on surface, reduce the gain (6db), change back to Trim on surface and reset the trims to 0db on both.
Thanks Stix, is there a way to prevent monitors from changing/accessing the pre amp after we set it up w/trims on surface??? nothing personnal monitor mixers, but I usually get different mon guys in different venues…
So is there a fails safe way to do both foh and mon.? no matter what I try I get either the editor affecting the surface mix and vice versa… is there a way to know when your in what state and when your not…???
storing to a scene… the thing is, scenes in editor are not necessarily the same as the ones stored on the surface…unless you copied them from the usb key …and named them the same!!!so If I’m in a mon/foh config…whatever one is doing eventually acts on the other…I saved 2 scenes on the surface called them x and y did the same in editor called them v, w…when I recall w in editor i get a state of" unknown" on the surface…i.e. its neither x nor y , iif ts scene 1 in the editor it recalls scene 1 on surface …and the more changes are done to scenes the worst this gets if you have more than 1 editor (1 at foh and another at mon for ex and a surface.) the state I’m talking about is the one where I would know i am affecting mon or vice versa or i’m not…I guess that is easily done by setting up a totally different “custom” config in the mon section making sure nothing done there is actually affecting the foh…but then there is the situation when you save scenes etc at foh using the editor… kind of damned if you do damned if you don’t ! so there must be some other way of doing this?..I like to save a lot when using computers…so archiving every little change might ( as I found out) not be the way to do it…store all in scenes seems much faster, so maybe I must look at this in a different way!!!
Also the only way I found to know which scene I am in is to look at the surface …no feedback from the editor!!! so if I haven’t named my 3rd scene on the surface but I have in the editor I am shown a “no name” scene although the # 3 is there so I know its the 3rd…but I don’t know that in the editor??? or have I not found it??
to continue on this…the "surface " tab in editor either affects the surface or doesn’t!! I can have a totally different aspect to my editor surface from the one actually represented on the actual surface…however if I store that to a scene in the editor these changes don’t necessarily appear at the surface…so again is this a case where either I want to change something faster by using the editor rather than the surface but I do want the surface to reflect the change…I’m just trying to figure out what’s the best and safest way to do this…
