The other night, I wanted to see one channel on the RTA, I didn’t care if it was on the iPad or the EQ “fader-flip” button on the console.
Can this be done?
I could not figure out how, so I assigned that channel to a mix that I was not using,… then I solo’d (PFL) that mix and used the fader flip for the 28 band EQ. It seems like there has got to be a more efficient way to accomplish this, but since input channels don’t have 28 band EQ, maybe not.
In GEQ Fader Flip mode, the channel meters actually behave like an RTA display (with peak band indication) to aid GEQ use, for example in case of feedback. Be aware this is still analysing the PAFL bus, which is not necessarily the selected Mix. Some might find this confusing but it gives you more flexibility should you want to RTA (PAFL) a measurement mic whilst tweaking the GEQ.
One to be aware of certainly. And possibly really quite confusing - I wonder whether they would be better “off” unless they are measuring the active mix…
