I was wondering if the channel routing is part of the processing block and you can’t block it if you want to change the routing of a channel from scene to scene, for instance adding a different aux.
The manual says that the preamp filter affects the input channels and socket routing, excluding DEEP preamp models. What does that mean? I can’t find an explanation in the manual. I noticed however inserting the tube preamp model in a particular scene it will be recalled.
