Using SQ mixpad with SQ7 and SQ5 on different shows
I work with 2 different groups, a high school that owns an SQ7 and a local drama guild that rents their console. I have SQ Mixpad installed on my laptop and I have used it with the SQ7 both on line and off line. The rental for the drama guild this time is an SQ5. I would like to do some pre rehearsal programming for the SQ5. When I open SQ Mixpad on my laptop at home, it comes up as an off line SQ7. Is there a way to change it to offline SQ5? If I do my preprogramming on the offline SQ7, will I be able to push the show into the SQ5? Do I need to have a seperate version of SQ Mixpad for the SQ5?
Yes.
Found it. Thank you!
You can pre program on the SQ7, just don’t use strips 17-32, soft rotaries, or soft keys 9 onwards.
And remember there’s fewer local I/O ports.
