V1.30 Firmware and GLD Editor released
Allen and Heath are pleased to announce GLD Editor is now available for download.
This is released with V1.30 firmware, which is required for Editor.
For details of the changes please read the release notes.
As with previous GLD feature releases, V1.3 also incorporates new versions of GLD Remote and GLD OneMix for iPad. These new versions also provide support for iOS 7.
GLD Remote 1.3 has been approved by Apple and is available shortly from the app store. GLD OneMix 1.3 is still going through the review process and is expected to be available in the next few days.
If GLD OneMix is critical for your business, you should therefore delay updating your GLD to V1.3 or updating your iPad to iOS7 until a further announcement from Allen & Heath.
Antony Jackson
Software Manager
Allen & Heath Limited
Excellent news! However the page appears to be broken :frowning_face:
“Unable to display this Web Part. To troubleshoot the problem, open this Web page in a Microsoft SharePoint Foundation-compatible HTML editor such as Microsoft SharePoint Designer. If the problem persists, contact your Web server administrator.”
Great news! Although the link on the home page isn’t working and there’s no “editor” section in the “GLD Products” page. [:smiley: ]
Chris
Hi All,
As noted above, there are some issues with the deployment to the web site, hopefully they will be resolved soon.
Thanks for your patience…
Antony Jackson
Software Manager
Downloaded and installed. [:smiley: ]
Chris
Downloaded, installed, done some off-line messing around.
So far I’ve managed to run it on 64-bit Vista, and via Wine on my Ubuntu 12.04 install (including loading a show file from USB) without crashing in either case.
Why? Because… [:smile: ]
Installed today. Pretty cool. Few quirks. Windows don’t size well on Win 7 laptop. Can’t resize. With overlapping windows, when you open a processing window like PEQ, then you can’t click on the knobs without that screen overlapping the PEQ window. Having 2 monitors extended would work but not practical on laptop.
Screen favors QU16 upper part without touchscreen. I guess banks don’t switch to allow local operator to still mix without remote person messing with them, but faders do mix from editor. Few other things don’t function also. I like doing routing, PRE/POST, MIx on/offs. Nice having large screens to see other than the small screen on GLD Easier to read. Keyboard to enter names is nice. Not crazy about the way you select number fields in naming and other parameters. You have to mouse or touchpad up/down. And the Start/End thing is not real great. Those are first impressions…
GLD 80
AR24/12
i checked out the offline editor yesterday! Great tool for preparing a show! i just miss the “COPY/PASTE” function! As well as the “RESET” button!
However… thanks to the offline editor i could send a prepared show to a friend without using my GLD-Surface which is located in our storing place!
Go on A&H! (Qu16 Firmware next! :wink: )
GLD-80 / AR2412 / AR84 / Qu-16
Hi eotsskleet
You can copy and paste various parameters by right clicking on buttons in the surface simulation.
  • Jeff, A&H
Hi eotsskleet
Copy/Paste/Reset are availible on Editor using the right click menus. From the help manual:
“Right click any ‘Sel’ button to copy, paste or reset the associated processing parameters.”
“Right click any ‘Mix’ button to copy, paste or reset the mix levels and routing (does not affect Pre/Post settings)”
Furthermore, Copy/Paste/Reset works with Preamp/Trim, HPF, Gate, PEQ, Compressor amd GEQ by right clicking in the processing section when a channel is selected.
Hope this helps
Regards
Sam A&H
Perfect! Thanks!
Please check on fix for better screen control. Sizing windows and ability to adjust controls without processing window disappearing. Otherwise happy. I see the naming thing is being addressed on another thread. I figured that out but clumsy. Something are more difficult with the data entry knob.
GLD 80
AR24/12
Installed, work correctly via Wi-fi and LAN.
It will be very cool if a “mirror” option will be avaiable, for example, if i open an EQ windows on GLD, it opens also on laptop.
bye.
Luca
What about the USB side of the Memory/show window? Can’t seem to get that to work. I am inserting a USB drive that I use on the GLD surface. Has shows and audio on it…
GLD 80
AR24/12
You need to go into the editor preferences and tell it where to look for the flash drive.
Chris
Chris: Thanks…Dummy me. I just never saw it I guess…That works…
GLD 80
AR24/12
I realize I am one of a minority of users that uses Windows 8 RT. However, I was hoping there would be a release that included Windows 8 RT. I have used it with my Windows 7 laptop with fantastic results, but I was looking for a bit more mobility. Is it worth it to recompile the program to work with the ARM processor or are there not enough of us Surface users out there?
GLD OneMix 1.3 will be available shortly from the appstore. If you’ve been delaying updating to GLD Firmware V1.3 or to iOS7 while waiting for OneMix, you can now go ahead and update.
Exact availability times will vary depending on where you are in the world - if you can’t download the new software yet, check back in a few hours.
Sam Warner
Allen & Heath
Looks like GLD remote v1.30 has also been released…
Rick
GLD80, AR2412, AR84, MMO, GLD Remote, KR202 array
