Has anyone noticed if you change your mix configuration (add a stereo matrix, etc…), once it’s done, all your pans, Aux send levels, pre/post settings are reset. This is not cool. I don’t remember this being an issue before. Please comment and let me know if this will be fixed soon and/or is known about. Thanks!
When adjusting the compressor ratio on the surface (144 in my case), the physical LED on the console is showing past the “6” mark, but the screen is showing 4:1. All other dials seems to be fine as far as the physical LED layout and the number showing in the Compressor view on the screen (Gain, Attack, release). Screen seems to be right, LEDs on the surface for the Ratio seems to need some calibration.
