Version 2.02 Screen
Hello I have Updated my Avantis to 2.02 Version. The right Screen on the Avantis ist Always Frozen.
The console appears to have crashed due to a hardware issue during the firmware update to version 2.01. The problem is not with the firmware itself.
If you haven’t already reach out to AH via the official support method (located on the main &H website), I would suggest that you do so. This seems to be a a very specific issue that your console is having rather than a larger issue affecting the entire community. The support team will be able to help you much better than we can.
Have you tried downgrading back to 2.0.1 or reinstalling the 2.0.2 update?
I Looks Like a Hardware fault. I have downgreating to 2.00 the fault exist Always und upgeading too 2.02. But I am in contact with the Support. He Look what i must downgreat to load all Tribe. Or her must Look with the Service Tool what happend to Change Hardware. It can bei the reason a USB Stick for example.
Use the left display to navigate to the Utility/Utilities/History tab. In the lower-left corner of the display touch and hold Options and touch anywhere in this screen to access an option to Show detailed Event Logs. Now check to see if you can find a line somewhere that indicates an error with the right display. If you plug in a USB flash drive, you can use the Copy Logs To USB Key button to save the error log and send it to support. It can speed up the debugging process.
But it is indeed possible that it’s a hardware failure. :frowning:
We know, WE are working in IT im am in contact with Support. First we want testing downgread, that the drivers are loading correctly. Und eventuelly If it Work Upgrade.
If Not WE Look at Hardware. The Protokoll didn’t say exactly what happend.
