Virtual sound check with Dual Rack and Dante
Hi, I have a setup with dual rack (idr64 and idr16) and Dante installed in a church. We use Dante primary to feed the ME-U For the IEM. And recording the sermon. We have also discussed the possibility to do virtual sound check. Which is fairly simple in a standard setup, but how do I route the signals from the Dante to the correct channel back to the Ilive. 10 inputs are coming from the idr16 (drum), all others are from the master idr64.
Cheers paul
Sent from my iPad using Tapatalk HD
Not really complicated- first you route the dante channels to ACE channels into slave rack, then chose ACE channels as source for inputs into master rack.
ddff
