Lately I used virtual soundcheck and the level in all channels were about 6db louder than the “live” levels that were recorded. I could also reproduce this later.
For recording and playback I used Studio One. It might be related to Studio One but I used it many times before with other consoles/interfaces without this problem. That’s why I am asking if someone also encountered this problem or has a tip what settings I can check.
Faders in Studio One are all at zero and no plugins are inserted, so playback should have exact same levels as recorded.
There will be differences with different setups for virtual soundcheck, and although you could account for these with USB trim, we would recommend compensating in your DAW and then creating a template instead.
This was discussed recently for Qu here ( https://community.allen-heath.com/forums/topic/virtual-soundcheck-with-qu-24#post-93385 ).
With SQ however, I would also suggest making use of Tie Lines.
Tie Lines can route input sockets directly to output sockets, meaning as long as you take care when setting up and are not constantly changing your input socket to input channel patching (one-to-one is always a good plan where possible!), you will be able to leave this set ‘in the background’.
Then you can make use of Input Channel Patch libraries to switch between your ‘live’ input patch (from mics/line etc.) and ‘VSC’ input patch (from the DAW).
ok, we already compensated for the difference in the DAW. Thanks for the affirmation.
But I don’t quite get what you suggested the Tie Lines for. Did you mean to path input sockets to USB output sockets? In which way does this effect the use of patch libraries? We already use patch libraries without using tie lines for switching between local/slink and usb.
@volunteer Thanks for the hint to the actual cause.
Using tie lines for recording is slightly different to working with direct outs and there are a benefits for each method depending on your setup and workflow.
If you change your input socket to input channel patching a lot for example, then it would make sense to use the direct outputs for virtual soundcheck recording as the socket would change, but you’re always recording the processing channel.
Or if you want to carry out virtual soundcheck and then switch to a recording setup for the live event with the same setup but processing included (i.e. you can switch the global direct out from post-pre to a post-processing point just before the actual performance), again, direct outs would be the way to go.
If however, you use a ME system (which you would want to use direct outputs for) you would definitely want to use tie lines.
Personally I find tie lines the easier concept for VSC, as it means it is the source/socket which is being switched between the live and virtual/recorded signals, without touching input processing channels.
Rather than using direct outs where the tap off must be checked. Also, when playing back from USB/Dante/Waves, I know I’m not sending the recorded signal straight back out to the recording device again (just in case I mess up something with the monitoring!).
Since we actually use a ME system this is a very helpful advice and totally makes sense. Thank you for taking the time to describe pros and cons of USB recording via Tie Lines in greater detail!
Hi folks,
Yesterday I got the same problem of a wrong level while playing back from the laptop.
For those who are interested in the real reason of the behaviour:
the keyword is very simple: panning law!!!
(has nothing to do with headroom, or anything else…)
