I am running a softsynth on a midi track in Ableton and sending it to channel 23-24 via USB. I’m processing it in the Qu and would like to send the processed audio back to the DAW for recording. How can I route this? Kinda running around in circles here.
In this scenario, you would record the audio from channels 23 & 24 with a post delay setting on the direct output source. This will show up and inputs 25 & 26 in your DAW if you have the default USB Audio patch.
I do indeed have audio getting to 23-24, processing is fine, in the routing section Direct Output is set to Post-Delay. In “source” channels 23-24 are set to USB Streaming.
Nothing is showing up on 25-26 (I do have the default USB Audio patch).
