WARNING - Concerning Lock Surface
Hi Guys,
during getting to know my brand new QU16 running Firmware 1.2, I figured out there is a bug in the Lock Surface function.
If you press any soft button configured as mute group while the surface is locked, nothing happens as expected.
Now if you unlock, everything is fine still…until you push any PAFL or Select button, then the before pressed Mute Groups is suddenly active and in worst case you will have zero output.
I hope the A&H Team will fix this, better already in 1.3.
Confirm fixed in V1.31.
