Waves Multirack and Tracks live
Need a little help. Having trouble setting up recording and multirack at the same time. I can connect and use Multirack Soundgrid or Tracks Live separately, but not at the same time. 2nd computer always says waves card already in use. What am I missing? Thanks for any help.
On the first computer, you run Multirack Soundgrid. On the 2nd computer, you run the Soundgrid driver, only. Is that what you’re doing?
Hi DMLMIXMAN,
Waves soundgrid is a bit confusing in that sence that one computer has to tell the waves soundgrid network to send the multitrack data to the other computer, although it is possible to have both one the same it is not advisable…
Best way is to run the soundgrid multirack version and go to the inventory in the audio menu, there you should see your waves card, server and local drivers, when a second computer is detected on the network it will also be shown here… you could set the computer running the multitrack recording to the same “assign” id so they can all talk to each other.
Next you would have to route the apropriate channels to the multitrack recording computer in the soundgrid connections menu, also under audio…
I’ve got attached some pictures, although they show offline since my setup is not connected right now, but it should show you the basic setup…
For the above explained…
Soundgrid inventory
Soundgrid connections
Eliaudio, Thanks for the reply. I’ll give that a try tomorrow.
Eliaudio, Thanks so much for the help. Worked perfectly!
No problem, nice to see it was helpfull…
