What show is currently loaded?
I can’t figure out what show is loaded. I’d love to know so that after I upgrade the firmware I can recall it. Help!
Does it appear as the “Last Show” on the screen with the “Power Down”, clock, firmware version? It’s misleading because it says “Last”.
I don’t understand the problem.
the last show that was loaded remains in memory.
you must know which show you loaded, right?
if you change any parameter it does not match the last recalled show anymore
so this makes no sense at all
the last state is always present
save a state to a show and give it a name you remember, that easy
but if you changed something after the save these changes are lost after the next recall
