When I unplug guitar from the direct box (channel muted) the mixer shows peaking signal. Is this normal? Is there someway the signal can be cut off so it isn’t showing a peak signal.
Not so uncommon to get a pop when unplugging a cable from a DI and or the instrument.
What DI are you using? Are you using a mono/TS cable?
This is not the problem with the mixer, more the problem with the cable or the guitar
that’s why Neutrik introduced “The Silent Plug”
Muted or not, the mixer will always show input signal on a given channel if it is present. This is normal behavior.
This is not the problem with the mixer, more the problem with the cable or the guitar that’s why Neutrik introduced “The Silent Plug”
I made up a couple guitar cables with those to carry with to carry with me for the
guitar players who either forget their guitar cables or the one did bring cuts in and
out making noise all time.
Silent Plug
I could probably make some extra money at shows setting up a stand selling guitar strings, cables, picks, 9 volt batteries, guitar stands, guitar straps, tuners, drum sticks, drum heads, snare drums, cymbal stands, ect.
That’s a short list of items that bands have forgotten to bring to shows I have provided sound for.
The silent plug sounds interesting. It is just that on any other mixer when the channel is muted it doesn’t show signal when unplugging a guitar. I don’t know if it really matters because it only shows up on meters. It’s just that I have never seen that on any of my analog mixers with the muted on or the channel off. Thanks for your reply and would love to see more info on silent plug.
Thanks, Jim
Thanks, Jim
The “silent plug” is normally used at the end that plugs into the instrument so when the cord is unplugged it shorts the cable so it’s not acting like antenna.
The small ring around the edge slides to activate the internal switch.
Cut one end off of a guitar cord and replace it with a silent plug. If you don’t solder
it’s an easy job for someone who does.
@Jim
totally normal per elec101 if you did not turn the related power off first
hopefully you had muted the channels on the SQ first
totally normal per elec101 if you did not turn the related power off first hopefully you had muted the channels on the SQ first
Nobody powers down a system to plug or unplug instruments, mics, DI’ ect.
Pay attention to what’s happening on stage is part of sound system operation
multi tasking though musicians can be quick and unplug something before you
see their hand reaching for the cord.
An all band input mute group is handy for set changes.
I will say I have had quite a few that will give you a look and point to the cable
to give you heads up that there going to unplug.
I always have channel muted before unplugging a guitar or any high impedance input. It doesn’t make noise it just shows up as peak on mixer when plug is pulled out. Just wondering if it is hard on the mixer when it peaks like that? Would going to channel and using the pad help?
Thanks, Jim
You should always, ALWAYS!!!, mute the channel before you plug or unplug the connected device, whether it is a guitar, microphone, keyboard or anything else. But it should not harm the input circuit, at least I cannot remember any problem after doing that job for more than 40 years.
Not power down the SQ but power down the device you are removing and mute the channel strips.
I would not expect harm but I would expect to see what the OP noted on the meters.
If an input channel needs or had phantom power that should be shut off before
connecting or disconnecting any the XLR from the mixer or connected equipment
and of course muting the channel.
An active DI does not need the phantom power turned off to connect or disconnect
the source plugged into the DI input.
