Why can`t i "recall safe" the gain?
Whats the reason the gain section is taken out of recall safe?
If i want to put an channel on recall safe, then i want not to change the PAD, or the gain - so why is the gain section taken out of the recall safe?
Albin
Using iLive T112 and IDR32
quote:
Originally posted by albin
… - so why is the gain section taken out of the recall safe?
From the manual:
This is because preamps can be patched to any input
channel, may be mapped to more than one channel, or used
as sources to other parts of the system which may not be
associated with the channel you want to make safe.
But you’re right - there should be a global option to include the preamp. I already asked for it - lets hope it is included soon.
Greetings,
Walter
That’s a problem. In theatre, you might have an actor with a sore throat, an understudy, etc. So the gain needs to be adjusted in each scene. Not having a traditional analogue gain control to tweak, I would really need to be able to Recall Safe the gain.
If I did have the socket mapped to several channels, I’d still think I’d normally need to make the same gain adjustment on all inputs.
I would vote to allow gain recall safe by default, with an option to disable it for those who don’t want it.
I’m not getting my iLive-T until January. Maybe this much-needed feature will be added by then.
Dave
Gets my vote, would be handy
quote:
Thats why I only store channel mutes,levels,sends and routing for any actor channel in theatre show scenes. That way you can make changes to any gain,eq,dynamics settings etc on the fly without subsequent scenes resetting everything. To do this you need to first set up a scene with the custom store settings you require (edit scene and remove input channel processing etc for the actor channels) then copy this to multiple scenes. Then at show rehearsals just hit UPDATE scene (don’t ever store all!). At the end of each rehearsal go back to scene 1 and store all and this will back up all gain/eq/processing etc. If there is a problem during a show - just change the gain - or eq etc as these settings won’t be reset with any scene recalls other than Scene 1. No need to use input safe mode at all and you still have recalled levels/mutes, sends etc. I generally don’t store any ouptut settings either for similar reasons. You can then freely eq FOH, monitors, change levels etc for differing crowd sizes and so on. Works for me!
Stix
T112 IDR48
Great Idea , keep an eye out in upcoming firmware…
version 1.54…still no change for this item.
a global switch in mixer preferences like “copy reset / scene safe includes preamp” would be great.
this allows you to decide whether you want to copy the preamp with channel selects and therefore also keep it scene safe or not. i think this makes sense.
