hello everyone, since the last update 1.2.0, we can no longer connect with CQ4You, IOS asks for a password, all CQmix pad and CQ4YOU applications are up to date. what should be done ? Thank you for your help
Are you sure the network settings didn’t get reset when you upgraded?
96% of the time when devices fail to connect it is because the two devices are on different networks or network segments. 3% of the time it is a firmware/software version mismatch. The other 1% of the time it’s due to a hardware failure.
Hi Brian , thank you for your answer, I just found the solution, update 1.2 sets a password by default, you just have to change it and enter it in IOS to be able to connect, thank you for your attention
Glad you found the solution!
