Hi All
Have used the mixer about 4 times with no issues. Has been stored in its road case for about 8 weeks and now it seems that the built in WiFi is not functioning.
Firmware has been updated and compatible with the CQ mix pad Versions. Tried 4 devices 2 tablets one windows laptop and a Samsung Mobile. All show same message.
The Mixer doesn’t show up , and putting the IP address into the connect option gets a “unable to connect”.
Have done a RESET of the Mixer.
Bluetooth is functioning perfectly.
its as if there is no Wifi on board at all.
Any suggestions?
Sorted it with advice from the supplier. Forgot to disconnect from the other Wifi first.(operator incompetence strikes again).
Glad you got it working.
I will simply add that while the CQ has built in WiFi, I would highly recommend that you ditch it and use your own network device for this use. Not only will you get a much more stable and reliable network, it also helps prevent situations like the one your just experienced. Personally I really like the GL-iNet travel routers like the Opal. For about $30, you can get a well rounded network device that will be much easier to use. That is money WELL spent IMHO.
