Will this box work with a A+H QU-32 board?
I found this on chuck levins seems like a good way to get an extra 4 channels going to the stage along with our analog snakes if it in fact works with the QU-32…
It won’t work via the QU’s DSnake network port, if that was your intention. That is a proprietary protocol only supported by the Allen & Heath digital stage boxes.
The box you linked to and the many like it are not even digital audio they are good ol fashioned analog and just use the conductors in a CAT5e or CAT6 shielded cable to carry the signal.
Just for fun of the many versions of those out there they all do not use the same pin outs.
Those are sold as stage sub snakes, maybe it’s just me but using a piece of CAT cable laying around on a busy stage getting walked on, musicians rolling stuff over it would not be something I would trust.
Thanks for the explanation. Yeah the DSubs are so expensive I wish they would have allowed a chaeper way to use a digital snake. But I guess we will just use old fashioned analog snakes.
Analog snakes are much more expensive, if they have the same channel count, quality, and length. Try to avoid the cheapest ones, the plugs don’t last that long.
How long and how many channel snake do need you from the stage?
As mentioned once you start getting into a 16 and higher channel snake with return channels in the 100 plus foot length your are the point where a digital stage box starts
becoming more cost effective and easier to deploy.
This is based on a legit analog snake cable.
