As stated showing stereo inputs 1&2, 3&4, 5&6, 7&8 but not showing the expected 16 inputs outputs show 4 stereo outs 1&2, 3&4, 5&6, 7&8 instead of expected 32
how do I fix this?
thank you
how do I fix this?
thank you
If you’ve not got the ASIO driver yet, download it from here: https://www.allen-heath.com/resources/
Thank you, I think I did but will double check
Thanks for that, clearly overlooked that important step
Awesome, missed the setup in the cog wheel in trax:
Using the QU5 I request track names and they do not populate nor do the physical faders control the faders within the software
The MTC functions are working and I am able to record signals
What am I missing now?
Thank you
Well after poking at it for quite a bit got the populations working
I realize there’s no real integration between QU5 and faders, select, solo, pan, & mute
Thanks for your patience
All the bullet points in these routing notes are gold
